I'd like to create points on some songs were the stem vocals are triggered to turn off. Is there a way to create cue points (or similar) that triggers the stem vocals off or on?
For example, I've been creating auto-skip cue points on songs using action codes like (goto_cue 4)
I hope this makes sense. Thanks for any help.
geposted Wed 21 Dec 22 @ 1:26 pm
You can use action POIs and use scripts like stem_pad 'vocal' to turn the vocals off. Then use the same action again to bring them back.
geposted Wed 21 Dec 22 @ 1:31 pm
YES!!!!!! Thanks, brother. I could kiss you. That's perfect. Cheers!
geposted Wed 21 Dec 22 @ 1:46 pm
Did you also see the replies to your post, 8 days ago? (may also be of interest)
https://virtualdj.com/forums/249802/VirtualDJ_Technical_Support/Auto_Trigger_Stems.html
geposted Wed 21 Dec 22 @ 2:47 pm
