Topic: Losing my cuepoints
What i'm going to do ?
I'm losing everttime my cuepoints.
I know it will be saved in the map documents/database.xml, but why it happen, i'm crazy about it.
I work with an imac en it saved in icloud drive.
Please help me.
geposted Fri 17 Mar 23 @ 3:59 am
Please remove it from icloud
Now you are basically letting another process control/update the file, without VDJ having any control over it or knowledge about it
oke, but how can i change that ? vdj set it automaticly in the database.xml
Or in what directory i set and change the map. I'm not an expert with vdj
Thanxks
every time this happens to me i have to reinstall an older version of vdj........and i always have to try keep and back up file of the old database
can anyone explain why it is happening?
it happened to op because he has his database on icloud
as for the rest you have, you given no meaningful details
Storing the VirtualDJ folder in iCloud Drive works well for me. No issues at all.
Something else must be going on in OP’s setup.
ICloud Drive is just a local mirror of a cloud folder, just like Dropbox. So, as long as you don’t have 2 machines running VDJ simultaneously on the same iCloud account, there is no problem with conflicting updates.
