Hi. Hopefully you can help. I’m trying to figure out how to put an echo out effect onto a pad fx. I have added it but when I press the pad the sounds just cuts out unless I have the master volume fx turned up. Is there anyway of doing this without having to have the master fx volume up? Thanks
geposted Tue 21 Mar 23 @ 8:38 pm
I don't know what script you have used, but you can try these:
and
padfx 'echo out' 90% 70% 62% 20%
and
padfx 'echo' 90% 70% 11% 75% 'Mute Source:on'
geposted Tue 21 Mar 23 @ 10:39 pm
Thanks buddy. I will give it a try
geposted Wed 22 Mar 23 @ 4:52 pm
help me to get my effect download
geposted Tue 06 Aug 24 @ 5:14 am
