Topic: loosing cue and song info...
hi
i have a very annoying problem....
songs that i had play over and over again with cues and full analyze vdj loose all that....
ex.
i play a song yesterday that i play it often, all ok with cues play count analyze.
today i see that the same song is not analyze and no cues and no play count....
this happen every time and songs are randomly
i reset settings but same....
any idea?????
macbook pro 2012 catalina os
geposted Wed 26 Apr 23 @ 11:00 pm
Have you moved the song around ?
Is the song on the same location it was yesterday ?
Have you done any database related operations ?
Is the song on the internal HDD/SSD or on an external location ?
Is your VirtualDJ home directory inside the "Documents" folder ? If yes, do you synchronize the "Documents" folder in iCloud ?
Is the song on the same location it was yesterday ? YES
Have you done any database related operations ? NO
Is the song on the internal HDD/SSD or on an external location ? INTERNAL
Is your VirtualDJ home directory inside the "Documents" folder ? If yes, do you synchronize the "Documents" folder in iCloud ? IS IN THE NEW PATH, NO SYNC WITH CLOUD
