Topic: CDJ Export Quality
Hi, I used the CDJ Export feature to Export the Cue-Points I set on Virtual DJ.
First of All, I was quite sad to see, that most of the Beatgrids are off and have to be re-adjusted (any idea why?). But then I noticed, that the waveforms of the exported files are a lot smaller in comparison to the original files on Rekordbox.
Is there any loss of quality when using the CDJ Export feature? Why are the waveforms smaller?
geposted Sat 29 Apr 23 @ 11:20 pm
Pioneer does not actually "share" how they calculate their waveforms.
Therefore VirtualDJ uses it's own way to calculate the waveforms, and that's what gets written on the CDJ database.
That being said, the audio quality is the same as both software just copy the original file on your USB drive.
What about the beat grids? this can be configured or something ?
