Hi,
Is there a way to create a macro whose function is to send a message (midi/osc/...) ?
and to assign this macro to an action point ?
I think it could be a great way to trigger resolume
geposted Mon 08 May 23 @ 10:22 am
Yes. You create a "virtual" MIDI device and then you define MIDI messages as LEDs or BARs.
Then you use script language on your POIs to turn on/off those LEDs and thus send the corresponding messages to Resolume.
Of course you need to do MIDI mapping on Resolume as well.
You can start by reading this thread:
https://virtualdj.com/forums/218737/VirtualDJ_Plugins/The_Advanced_Freestyler_integration_thread.html
It's made for another purpose but the main principles are the same.
geposted Mon 08 May 23 @ 12:04 pm
Awesome ! thanks
geposted Mon 08 May 23 @ 3:05 pm
