Topic: Looping out question
Hey Guys, noob question
when looping out my track, the track has skipped the part i was looping, so when i loop like 8 steps & i want to proceed from there, it start 16 steps ahead.
can't find the setting.
so, to be clear, when in loop out, i want it to play forward from the part i looped out!
thx
geposted Sun 21 May 23 @ 9:40 pm
If I understand the question, I think you want to set the Setting > Option > loopBackMode = No
Select, when a loop is set by number of beats ('loop 4'), if the loop starts from the current position (no) or ends at the current position (yes). Smart means set start when paused or set end when playing.
PS
also you may want to check out loopAutoMode
Select if the loop is kept and moved to the new position when a cue is called during a loop
