Topic: Help with Stems + fx script
Hi there,
I'm using the 'Stems + fx' add on and it's been super useful for me. The only thing that I would like to see different, is that the Vocal Echo and Instrumental Echo get a reset when you load a new song. Can anybody help me with this? Now when I've used one of these Echo's and I load a new song, both the stems buttons and the Echo buttons are lit up. The setting ResetStemsOnLoad is set to 'All'. The script is:
var 'stemsnfx1' 1 ? toggle 'stemsnfx1' & mute_stem 'vocal' : off & toggle 'stemsnfx1' & effect_stems 'vocal' & padfx_single 'echo' 0.5 0.65 0.25 0.75 & wait 1bt & padfx 'echo' & mute_stem 'vocal' & effect_stems 'vocal'
Kind regards,
Lennart
geposted Tue 06 Jun 23 @ 10:17 am
