Topic: Help Before Purchasing
Good Morning, I have a DDJ 1000 SRT and I am thinking about purchasing the full paid version of VDJ. I would like like to midi map the some of the FX's to the pads on the controller. Similar to the PAD FX1 and PAD FX2 on the DDJ 1000 Rekord Box Version, can this be done? I need to know this before making the purchase as to how customizable the software is. Thanks in advance. If this is the case I might Just switch software and just run VDJ instead of Serato.
geposted Wed 07 Jun 23 @ 12:42 pm
Sure, as long as t's VDJ FXs that you want to map
You can then create your own version of pads, called pad pages, and assign them to the pads selector buttons on the controller for easy access
Very fun to do :)
