Topic: In ear monitors, what you all using?
OK, so I was thinking of some in ear monitors with active noise cancellation.
Anything budget is going to be bluetooth, so I am worried that the latency is going to be poor
Looking at some mackie's around the £150 Mark, but they are still bluetooth
What are you all using
geposted Sat 24 Jun 23 @ 5:17 pm
Mine are KZ ZS10 (wired) from Amazon. Really good, considering they're not expensive.
No noise cancelling, but with them in, you don't hear much outside noise anyway.
Warning: Bluetooth headphones will have a signal delay, so you'll have trouble synchronizing your tracks.
My point exactly 🤔
I don't think "active" noise cancelation makes any real difference for DJ IEMs
After all, they are IN EAR monitors and their passive noise cancelation is pretty good to start with.
Personally I was using some Pioneer IEMs from 2015 until recently. This year I have switched to Shure SE215 and I'm pretty happy with them.
I also considered to get the higher model (SE415 I think) but for now SE215 fills my needs perfectly.
PS: I use a "cheap" wireless IEM transmitter and I don't have latency issues. However the "cheap" transmitter can saturate frequencies lower than 40/50 Hz at higher volumes. So, in my case, my next step is to change the "cheap" transmitter to a better one. I'm looking at some Shure transmitters at the moment, but I have not decided yet.
I want to try the KZ ZS10, but right now I'm using ZERO AUDIO-ear stereo headphone carbo Basso ZH-DX210-CB. It use to be on sale, but it isn't anymore. The bass sounds good and they do get loud with a headphone pre-amp and amplifier.
