Topic: SC Live 4
Hello VDJ community,
I have the SC Live 4. The internal effect at Denon Wash is at VDJ Noise. Would like to have the wash effect at VDJ too. Is that somehow possible?
Greetings from Germany.
geposted Tue 11 Jul 23 @ 5:26 am
The SC Live 4 is using software/VirtualDJ Effects in Computer mode, there no Hardware Effects in this mode.
There is no "Wash" Color FX in VirtualDJ, but you can still select any of the available to replace the pre-defined Noise, as these are mapped with VDJ script actions
Thanks for your answer. I've tried mapping the Loop Out effect to the button on the wash, but I can't get it to work. what do i have to do?
Thanks
loop out isn't an fx suited to color fx, check the dropdown for colorfx to see the available options.
Hello,
Greetings
so no way to use a wash fx with vdj
