Im trying to the stems pad page and cant seem to get it right. So I want to Solo the vocals and turn on loadmax and when I disengage the vocal stem loudmax turns off. Now if I can add 3dbs to the midrange in Acapella and that also turns off when I disengage Acapella also would be nice too.
    geposted Thu 27 Jul 23 @ 3:20 am
          You probably need to post the scripts you have written, for them to be verified
    geposted Thu 27 Jul 23 @ 4:15 am
          stem_pad 'vocal' & effect_active 1 "LoudMax64"
    geposted Thu 27 Jul 23 @ 6:14 am
          What would you like to happen?
On a padpage, the script you posted, a L-click (normal click), or normal press, will MUTE the vocal stem and active the LoudMax64 in the first slot.
(second L-click will UN-mute the vocal stem and DE-active the LoudMax64.)
Note: R-clicking or shift-pressing the pad will SOLO the vocal stem and active the LoudMax64 in the first slot. (If all 5 stems are on, the full track, else it will remove the vocal from the partial track)
The second R-click or shift-press will play all 5 stems the vocal stem and DE-active the LoudMax64.
(If all 5 stems are on, the full track, else it will add the vocal stem back to the partial track.)
Summary: in your script the LoudMax64 is toggled on and off with each click.
Again do not know what you wish to happen.
For example, if you want to keep LoudMax64, (in slot 1) active after the second press, you need to query, if the LoudMax64, is active, and then, NOT turn it off, if it is Active.
Hope that helps get things started
you may also be interested in:
stem_pad 'Acapella'
and
stem_pad 'Instrumental'
with the simple behavior..... always solos and 2nd click un-solos
(not dependent on R or L click or states of other stems)
stem_pad 'Acapella'
and
geposted Thu 27 Jul 23 @ 7:52 am
          stem_pad 'acapella' & effect_active "LoudMax64" this is the successful script but how do I add setting the sliders...like the top slider sets to -6 and bottom slider to -3
update: ok this works
stem_pad 'acapella' & effect_active "LoudMax64" & effect_slider 1 80% & effect_slider 2 90%
but it only works on deck 1 it doesn't set the slider when using deck 2.
geposted Sun 13 Aug 23 @ 12:24 pm
          you haven't said which effect you want changing so it assumes slot 1, include the fx name.
    geposted Sun 13 Aug 23 @ 12:48 pm
          The effect name is Loudmax64 it turns it on it just doesn't set the sliders when on deck 2. Deck 1 works pperfectly
    geposted Sun 13 Aug 23 @ 6:55 pm
          it switches on because you said which fx to turn on, for the slider you haven't specified the fx or the slot so it assumes slot 1
    geposted Sun 13 Aug 23 @ 7:06 pm
          I get what you're saying now... so how do I write that?
    geposted Sun 13 Aug 23 @ 7:14 pm
          read the in app definition for effect_slider and think where the fx name could go.
    geposted Sun 13 Aug 23 @ 7:31 pm
          stem_pad 'acapella' & effect_active "LoudMax64" & "LoudMax64" effect_slider 1 80% &  "LoudMax64" effect_slider 2 90%
This is what i thought but its not working.
geposted Sun 13 Aug 23 @ 11:35 pm
    geposted Mon 14 Aug 23 @ 11:29 pm
          Read the script school thread, I've given you, YOU PERSONALLY, dozens of scripts with effect_slider applications. I didn't write those tutorials for my benefit.
If you were a beginner I'd have given the script already, but you've been here for years.
I've honestly had more success explaining script to a blind non-english speaker than I have with you. That isn't exaggeration.
geposted Tue 15 Aug 23 @ 12:19 am
          Well ok... Im cool with that... i just don't get this scripting thing I do try I just don't get it. But its cool. I wont ask for any more help.
    geposted Tue 15 Aug 23 @ 12:29 am
          Admin can you all delete this thread?
    geposted Tue 15 Aug 23 @ 12:30 am
          You'll only learn by doing it, try things.
    geposted Tue 15 Aug 23 @ 12:37 am
          Ive been trying this for 2 days...Ill just set it where I want hopefully it doesn't change when I exit the program
    geposted Tue 15 Aug 23 @ 1:08 am
geposted Tue 15 Aug 23 @ 2:03 am
          stem_pad 'acapella' & effect_active "LoudMax64" off ? effect_active "LoudMax64" on & effect_slider 1 80% & effect slider 2 90% : effect_active "LoudMax64" off
not setting the sliders.
geposted Tue 15 Aug 23 @ 4:02 am
          you've not included the fx name
    geposted Tue 15 Aug 23 @ 4:20 am
