Topic: VDJ and Showxpress/Lighting controller setup
Can anyone advise how to set up a connection between two laptops so I can have Showxpress on my Surface, which would communicate with VDJ on my main lappy? Both have Win11...
One thing which may complicate any suggested setup is that I also need my usual internet access to my main laptop, which is either WiFi or USB phone tethering.
Thanks!
geposted Wed 02 Aug 23 @ 12:24 pm
Not sure why you need two separate laptops?
I have both VDJ and ShowXpress running on the same machine with no issues whatsoever.
I have limited USB ports on the main lappy, I would like to see the live DMX buttons at the same time as VDJ, my main laptop is not touch screen, I can put a second tablet anywhere close, it can be used for dmx control by another person while I'm djing...
It works flawlessly on my main lappy, but just not convenient for live control
My settings in ShowXpress are:
File>Preferences>
Network:
Software: 127.0.0.1 port 7347 UDP
External App: Enable port 7348 TCP
VirtualDJ: Enable port 7350 TCP
Hardware:
Address: Your VDJ PC, communication port 7349
Web server port 80
Autodetect interface: Enable use broadcast
In VDJ:
Settings>Options>Internet:
os2I Yes
Works perfectly for me with two PCs Windows 10.
