Hi, on start up on the Denon MC4000 controller the flashing lights usually only lasts for a few seconds but now when I turn on it flashes continuously . Any ideas why ?
Many Thanks.
Many Thanks.
geposted Thu 31 Aug 23 @ 10:34 am
That's part of the hardware initiation and not VDJ. If it keeps happening then try reflashing the firmware.
geposted Thu 31 Aug 23 @ 10:41 am
Many thanks, I need to get a USB lead for this controller and then see if a firmware update is available.
geposted Thu 31 Aug 23 @ 5:13 pm
Hello. Did you solved the problem? I have the same.
geposted Tue 17 Dec 24 @ 12:22 pm
