Discussion about A-BPM TR
    geposted Sun 17 Sep 23 @ 2:51 pm
          I cannot find it within the VDJ program  Where can I get it?
    geposted Wed 20 Sep 23 @ 2:40 am
          in VirtualDJ Settings-->EXTENSIONS tab, select the Pads ->Main category and Search for BPM
After you install it, you will find the Pad page in the drop-downs of each Deck.
Here is some discussion about it.. https://www.virtualdj.com/forums/254460/Wishes_and_new_features/Standard_Pad_Page_for_auto_bpm_transition__.html
geposted Wed 20 Sep 23 @ 5:35 am
          would you be able to make the "Vocal Out"....into....."Vocal Echo Out?"
If you can this would be soooo awesome!!! Please do it...
geposted Thu 18 Jan 24 @ 3:34 am
           the stems don't work for me.
    geposted Mon 28 Oct 24 @ 10:20 pm
          During the transition the VOCAL function activates the stems on both decks.
    geposted Sun 03 Nov 24 @ 4:22 pm
