I'm curious what this is, I'm hopping it's clockwise||counterclockwise
geposted Tue 26 Sep 23 @ 10:40 am
https://virtualdj.com/wiki/Skin%20Slider.html
Sensibility is how "sensible" the knob is to mouse movements.
If you want to set clockwise / counter clockwise movement for a round knob, then you can use
as child of the <slider> element
Quote :
<fader move="" sensibility=""> (round sliders only) : The move possible values are "full", "horz", "vert", "v" or "circ".
Quote :
direction="" : possible values: "cw" (default) or "ccw"
geposted Mon 02 Oct 23 @ 11:50 pm
Thanks, after considering, while ccw dial visually would make sense for lp filter [with on/off cols inverted] the right hand thread of how dials are expected to work is too strong to use otherwise,
but thanks for the info
geposted Tue 03 Oct 23 @ 12:27 am
What are valid values for sensibility? I can't find an example, and docs don't provide any hints.
geposted Tue 23 Sep 25 @ 3:56 am
1.0 is default, 2.0 would be 2x more sensitive, 0.5x would be half as sensitive
geposted Tue 23 Sep 25 @ 6:24 am
