Hi team I'm using virtualdj with ezremix mode (MCX8000), and am having issues with LEFT DECK, playing at nights left deck stems knobs stop working (always is left deck).
Build 7183, it my last update can i use with my machine. (Sierra MACOS, running with RAID cant upgrade).
I use internal knobs like Eq, external knobs Stems, and all left stems knobs stop working.
geposted Mon 16 Oct 23 @ 6:57 pm
Can you try early access build 7716?
https://virtualdj.com/download/build.html
geposted Tue 17 Oct 23 @ 6:13 am
Thanks Adion, but in this case my MACOS and machine are limited to Sierra :(, I will the way to upgrade to test it
About last build in mention, which MACOS is minimum to support it?
geposted Wed 18 Oct 23 @ 11:49 pm
https://virtualdj.com/wiki/Minimum+system+requirements.html
Then you're indeed left with 7183
geposted Thu 19 Oct 23 @ 3:08 am
