Ok
geposted Fri 03 Nov 23 @ 10:48 am
I can confirm the Stems are now functioning on the outer EQ's !
Thanks for the fix!
Thanks for the fix!
geposted Fri 03 Nov 23 @ 8:04 pm
It's just an opinion but when I use the Opus Quad it seems to sound a little better on Serato than on VDJ. I saw that there are some settings in the EQ parameters. Would it help if I went to these settings?
geposted Tue 19 Dec 23 @ 6:27 pm
No, Opus Quad uses it's own hardware EQ.
geposted Wed 20 Dec 23 @ 9:02 am
Thanks.
You are an experienced DJ in Virtual Dj. What do you think about the sound quality of Virtual Dj?
geposted Wed 20 Dec 23 @ 9:57 am
Can I change the mapping, via a combination of shit & cue to activate stems?
geposted Tue 14 Jan 25 @ 10:14 pm
If you mean to control stems via the EQ knobs, NO IT'S NOT POSSIBLE.
It's a firmware limitation. Pioneer/Alphatheta will have to update the firmware of the device in order to allow such operation (similar to what it did with DDJ-REV7)
geposted Tue 14 Jan 25 @ 11:12 pm
