Topic: Play Next on Remote
I don't see this anywhere. Love the new version of VDJ Remote, but I noticed that "Next Up" and the ability to skip to it are missing. Am I missing something or is it gone?
Thanks!!
geposted Tue 07 Nov 23 @ 9:52 pm
With automix activated, long press or use the dots at the right of the song and select 'mix now' or 'play next'
I don't see these dots you speak of...
Next to the track you want to mix to in the browser
Ah, in the browser screen. Found it, and thank you.
So, the "Next:" feature is gone? (To see what's next up, and skip to it).
Can't tell what's next in the Automix list...
Just checking..
Might be possible to add back to the skin in the deck view too yes
That would be cool. For now, I just tap the end of the track and let it fade into the next one...
I was surprised because I thought dev had stopped on the remote app. These new changes are very nice.
It's pretty much rebuilt completely, which is why it took longer than planned to make any updates.
