Ok, no matter what I do I can't get the echo effect off my microphone. I'm running a FLX-10 controller and latest build of VDJ and an echo will randomly kick in and WILL NOT TURN OFF. I've tried everything. Only after about 5 power cycles of laptop and board and unplugging USB connection cords will it go away...until it randomly starts again.
I'd appreciate any feedback!
geposted Sun 19 Nov 23 @ 9:09 pm
sounds like maybe its latency and not virtual dj
geposted Sun 19 Nov 23 @ 11:43 pm
I was thinking the same thing. He does say it's random though, which is odd.
VJMatt can you post a clip of what it sounds like?
geposted Mon 20 Nov 23 @ 8:28 am
Even though the FLX-10 doesnt have any USB mic input, there is a chance your OS auto-assigns the "record" input of the FLX10 as the default Microphone input. Check your Windows Sound Settings
geposted Mon 20 Nov 23 @ 8:42 am
Thanks very much for the replies. I will try and post a video ASAP.
geposted Mon 20 Nov 23 @ 7:35 pm
Im have a issue with mic having echo on it. If i use the console FLX10 just standalone without latop the mic works fine but as soon as i plug the laptop in and start virtualdj the echo starts on the mic on both mic channels. Everything else works like a dream.
Im using windows 11 12th gen i7 with 16gb ram
windows is not using my onboard mic i checked
thanks for any help in advice
geposted Tue 12 Mar 24 @ 8:05 pm
Did you read the VDJ setup guide for the FLX10?
geposted Tue 12 Mar 24 @ 8:31 pm
Thanks GroovinDj i did read the setup with both my eyes closed so took your advise read it with my glasses on and eyes open and found this
A Reverb Hardware Effect is available to apply to the Microphone Inputs.
To access control to this Fx, hold down the HOTCUE mode button (on any of the Decks) to get the FLX10 MIC page on Pads (or select it from the GUI) and then use the Pads to turn the Reverb FX on Mic on/off and adjust the Reverb Parameter/Level.
geposted Wed 13 Mar 24 @ 7:16 am
OK you found it - excellent, but was that the cause of the "echo"?
geposted Wed 13 Mar 24 @ 9:24 am
yes!!
geposted Thu 14 Mar 24 @ 5:31 am
LIFESAVER this thread . . . lol. My controller got soda spilled on it, and while I was able to take it apart and fix/clean it, the mic had the echo on it - I guess while the pads were freaking out from being wet, it selected that option. WHEW!
geposted Tue 26 Mar 24 @ 7:22 am
i had the same problem thanks for the help
geposted Fri 14 Mar 25 @ 10:08 am
I'm having the same problem but i don't have the controller attached and I'm still getting reverb noise
geposted Fri 12 Jun 26 @ 4:51 am
