On Rekordbox/Serato if I press SHIFT+CUE that makes the HIGH MID LOW knobs control each stem seperation (VOICE INSTRUMENT DRUMS). Is there a way to do that same function with VDJ? Also.. how do I get the FX PART SELECT on the FLX10 to do the same thing it does on Rekordbox/Serato?
Is there anything else the VDJ cant do with the FLX10 that Rekordbox/Serato can?
geposted Mon 11 Dec 23 @ 6:19 am
Thanks. It works but I cant use the SHIFT CUE option to switch back to FREQUENCY mode.
geposted Mon 11 Dec 23 @ 6:55 am
Sorry.. Im new at this.. I just did it in OPTIONS. How do I map it? Will it change back to FREQUENCY that way also?
geposted Mon 11 Dec 23 @ 6:56 am
geposted Mon 11 Dec 23 @ 7:03 am
Got it! Thanks! I know this is asking for a lot more.. but on Rekordbox/Serato if your using the knobs for STEMS then the CUE button will blink to let you know that STEMS is still on,.. Is there a way to do that?
geposted Mon 11 Dec 23 @ 7:09 am
It's not that simple for FLX-10.
Pressing SHIFT+PFL also toggles a few things on device firmware.
That's why we had to not include the SHIFT+PFL "eq mode" adjustment on the FLX10 mapping.
And the "blinking" part of the CUE (PFL) button comes from the device firmware.
geposted Mon 11 Dec 23 @ 7:53 am
that explains the weirdness, looks like you'll have to pick a different key.
geposted Mon 11 Dec 23 @ 7:56 am
locodog wrote :
map shift+pfl to
setting eqmode EZRemix ? setting eqmode Frequency : setting eqmode EZRemix
The rest I don't know what you mean, please elaborate, I don't use other SW.
So this works, but it turns all the knobs on all the channels to STEMS. Not just the channel selected.
geposted Tue 12 Dec 23 @ 3:23 am
Thats a shame. The whole reason I bought the FLX10 was for the stem options. Do you think the VDJ will eventually find a map for all the STEM functions the way Rekordbox and Serato has them?
geposted Tue 12 Dec 23 @ 3:25 am
This one went over my head a little. I couldnt find "LED_PFL", and not sure where this goes.
geposted Tue 12 Dec 23 @ 3:26 am
It won't work due to hardware limitations I wasn't aware of, usual cases it would work but not with flx10
geposted Tue 12 Dec 23 @ 3:27 am
Good reason. and yes everything works great with VDJ
You just need to map this specific switch function to something else on the controller :)
geposted Tue 12 Dec 23 @ 12:13 pm
Why should it ? I mean, why this:
VirtualDJ was the first software to offer Stems.
VirtualDJ has it's own logic.
VirtualDJ offers more than the competitors when it come to stems.
VirtualDJ may have similar functions to other software, but it does not want nor need to copy how other software works.
The same applies on controller integration.
VirtualDJ offers stems and tries to follow the silkscreen of the controller and the way the controller works with other software. However on several occasions the functions may be slightly different because the software itself (and the way it works) is different.
It's ok to want an extra feature. And yes you can map the equalizer mode on your controller if you wish so, but not on SHIFT+PFL due to some firmware weirdness from Pioneer.
What's not ok is to expect a competitor software to just copy another. Especially when in the function involved, VirtualDJ was the first "and the others copied"
PS: Don't get me wrong. I just want to emphasize that people should NOT want/expect VirtualDJ to "just copy" the functions of competitors. Basically they should NOT want/expect the opposite either. :)
geposted Tue 12 Dec 23 @ 1:15 pm
Hi there, I just got my FLX10 and was also curious about the "Part ISO" function. So I played around a bit and ended up with adding the following to my xml file and so far it works as I would have expected. (I admit that I don't know what the original behaviour with Rekordbox is :P )
This works per channel, not global.
<map value="SHIFT_PFL" action="setting eqmode EZRemix ? setting eqmode Frequency : setting eqmode EZRemix" />
<map value="SHIFT_LED_PFL" action="setting eqmode EZRemix ? on : off" />
geposted Thu 22 Aug 24 @ 12:56 pm
The actions above should work fine and i could say that in theory, these ^ could be the default actions too, in case we want to match the functionality with Rekordbox.
But ...
due to the device firmware, if the Led of the SHIFT_PFL is mapped as "true" (you turn it on), then each time you move the EQ knobs, you ll get the led of the PFL buttons to blink, so if you regularly use the Stems on EQ, you ll end up having the PFL leds flashing all night ! , even if SHIFT is not pressed, and that's something we found annoying, no ?
But ...
geposted Thu 22 Aug 24 @ 1:05 pm
Ahh, I see your point. For me the LED blinking counts as a feature not a bug since I want to switch EQ modes and wanna have some feedback about it. ;)
geposted Thu 22 Aug 24 @ 3:16 pm
Hi there, my case senario is similar in that when I first start up VDJ with flx 10 the fx part select are off be default upon starting VDJ. Is there a way for this feature to have on state upon starting VDJ. Not sure if it’s a limitation thing or choice by VDJ hardware team but if there is a way for me to change to on state I would be greatful. Many things
geposted Thu 30 Jul 26 @ 7:50 am
hi, i´m flx 10 user too.
what i did to get mixer modes inn each channel:
CF_Assign_A
set "$MS" 1 ? cross_assign 'left' : setting 'eqmode' 'EzRemix'
CF_Assign_B
set "$MS" 1 ? cross_assign 'right' : setting 'eqmode' 'ModernEQ'
CF_Assign_THRU
set "$MS" 1 ? cross_assign 'thru' : eq_reset & setting 'eqmode' 'Frequency'
SHIFT
shift & down ? set "$MS" 1
With this mapping can select modern o remix eqmode in each channel, and you can preserve original funtion of the switch if combine with shift, and add shift variation to CF_ASSING who does´nt exist
Regards!!
CF_Assign_A
CF_Assign_B
CF_Assign_THRU
SHIFT
Regards!!
geposted Fri 31 Jul 26 @ 4:44 pm
Hi there. Pressing shift and cue does that any way? I can get eq or stem eq as well as having eq on outer channels if needed if in 2 deck mode. This makes the flx 10 and VDJ probably the hottest combo. Issue I have is upon start up the part select fx buttons are on off state by default. Maybe this is by VDJ devs design to do that. Seems a bit odd though. I’ve tried researching and having a go but can’t seem to get it to work,
geposted Fri 31 Jul 26 @ 4:49 pm
try :
ONINIT
( deck all effect_stems 'rhythm' off & effect_stems 'vocal' off & effect_stems 'melody' off )
OR
ONINIT
( deck all effect_stems 'rhythm' on & effect_stems 'vocal' on & effect_stems 'melody' on )
Regards
Moderator Scripts fixed. see why your use of deck all was dangerous;
Be careful using deck all
geposted Fri 31 Jul 26 @ 5:06 pm
