Hey is there a brake effect that doesn't stop the music just applies the effect sound for Virtual dj?
geposted Sat 23 Dec 23 @ 3:10 pm
slipbrake8 fx
https://virtualdj.com/plugins/?addonid=80246
geposted Sat 23 Dec 23 @ 4:41 pm
Slipbrake8
geposted Sat 23 Dec 23 @ 10:25 pm
The track still stops but that will work the same one I've been using.
geposted Sun 24 Dec 23 @ 4:04 pm
So you want a brake FX that doesn't do any braking?
I guess that would be a sample then...
geposted Tue 26 Dec 23 @ 3:49 pm
Slipbrake8 is a script based effect, it just manipulates rampStopTime presses pause slip on wait a duration press play slip off. Therefore it brakes everything.
if you want audio based for use with effect_stems you can use the native breakstart effect on stem channels also there are hundreds of vsts available.
geposted Tue 26 Dec 23 @ 4:32 pm
