Hello in this tutorial I can show how I use my any external sound card like Blaster G5 to connect mixer master output to Microphone Input in order to change the track sound.
I know it's for microphones only and broadcasting quality can be lower depending of sound card model but it actually works for playing all tracks of your mixer master output.
So with my Blaster G5 card I connect that to PC or laptop on usb then I enable FXs with presets to change sounds as well. So basically for this card you have a few effect like Pitch, Formants, F1, F2, F3, Quiver, Modulation and Variability. You can modify the percentage of these all FXs or create own presets.
I hope you enjoy that if you had it too.
geposted Fri 05 Jan 24 @ 7:07 pm
