So I haven't played around with VDJ7 or my controller in 5+ years I was in the attic and i found it so I brought it down and set it up.
The issue im having is the speaker is playing oth sides not matter where the crossfade is at.
I searched a few times in the forums and the suggestions didn't help.
I opened up serato intro to see if it was my connections but it worked fine on that.
I feel like I remember having to open up ASIO4ALL n adjusting something there before opening vdj but it's been so long I can't remember. Anyone got any ideas?
Super old by now I know.
geposted Sat 13 Jan 24 @ 6:19 am
First of all, I'd highly recommend using the current version of VirtualDJ.
VDJ 7 doesn't get updated any more and certains aspects of it no longer work correctly.
The N4 setup guide is available here, and states that no driver is required, so you don't need ASIO4ALL.
geposted Sat 13 Jan 24 @ 10:10 am
1. (read there)
-----> https://www.numark.com/virtualdjleupdate
and
2. (read there and download asio4all)
-----> https://www.numark.com/product/n4
3. (search there for: setup with virtual dj le and try this way)
and
geposted Sun 14 Jan 24 @ 7:46 pm
Hi,
I have been using a numark n4 with virtual dj for the past 8 years.
I have a pro license.
I recently downloaded the latest version and I can get my controller to work properly.
The left volume , crossfade and headphones won't work.
Is there a way I can fix this
geposted Sat 28 Dec 24 @ 12:26 pm
