Forum: Music discussion
Topic: Impossible to livestream on Mixcloud with my hardware ?
Hello,
I have the Behringer xenyx302 USB audio interface and the matching Superlux HMC 660 X headset.
I also have a USB webcam with integrated microphone.
However, I can't create a live show on mixcloud via VirtualDJ with this setup. Either you can hear the music I'm playing but not my voice or vice versa, or I can't hear myself in the headphones or I can't hear the music... somehow it all doesn't fit together.
maybe someone has a similar setup and can help me with the settings?
Many thanks in advance
Christian
geposted Mon 12 Feb 24 @ 2:13 pm
As you're having problems with your audio config, please post a screengrab of your VirtualDJ audio config page.
You'll have to host the pic elsewhere and link to it, as you're not a licensed user.
Thank you so much! Will do so tomorrow afternoon!
Hope this is the correct screen..unfortunately it´s in German, but I think it might be easy to find out what is what.
This PHANTOM FADER seems to be my Behringer btw
https://i.postimg.cc/sxXhXyrw/VDJ1.jpg
I'm assuming it's not VDJ's fault.
It seems to me it depends on the device or how you use it...
Since the screenshot is in German, I assume it's easier to understand in German :-)
Go to the linked page and read the first text in the reviews.
Maybe you'll think of something...
With the MischMasch device you can hardly give any help online.
Moderator ASIO4ALL is garbage - don't suggest it again
Here the link:
https://www.thomann.de/de/behringer_xenyx_302_usb.htm
Ich gehe von aus es liegt nicht an VDJ.
Wie mir scheint liegt es an dem Gerät oder wie Du es nutzt...
Da der screenshot ja auf Deutsch steht gehe ich von aus es ist in Deutsch auch einfacher zu verstehen :-)
Gehe mal auf verlinkte Seite und lese da bei den Rezensionen den 1. Text.
Evtl. fällt Dir dann etwas zu ein...
Bei dem MischMasch-Gerät kann man kaum Online Hilfestellung geben.
ASIO4ALL besorgen wäre ein guter Anfang.
(Link steht oben)
i don't think the Behringer has enough lines on its own
by that i mean lines available on the USB interface
4 outputs are required to have master and headphones setup
Agreed. Small cheap mixers like that would typically only have a single L/R stereo signal in/out via USB.
You could use it to send the mic signal to VDJ, and also to monitor back from VDJ to the headphones, but you can't send the master AND headphone signals to it.
If you're broadcasting then you don't actually need to send the master to the Behringer, as that would be broadcast from the VDJ mixer directly.
I'd suggest setting the audio config to send the master signal to your computer's onboard audio if you need to monitor via speakers.
your mistaken the USB portion only has 2 channels output
that mean 1 right and 1 left IE stereo
you require 4 channel output on USB to use it for master and headphones
the channels you mention are the devices totals not what is available via USB
"the channels you mention are the devices totals not what is available via USB"
Yes, I've seen it now too.
Either 2 (left/right) to the PC or 2 (left/right) from the PC.
Not in both directions at the same time.
Ok, I see and understand!
I had almost feared that it was due to my equipment.
I'll probably look around for other hardware that I can use to do what I want to do.
But thanks again to you both, you've really been a great help!!!
Stay healthy and have a nice Sunday!
