Is there a way to use a POI action to change the key of a song without changing how the song sounds?
For example, if a song starts in Em and then there is a key change to Gm, VDJ still thinks the song is in Em, and so all indicators to aid with mixing in key will be wrong, along with auto keyshift functionality and anything else related to the key of the song.
I would like to use a POI action at key changes to let VDJ know that the song is now in Gm, but using set_key will instead shift it another minor third to Bb, which just makes Bon Jovi sound like the Chipmunks.
geposted Fri 16 Feb 24 @ 9:42 pm
From your description, you don't want to change the key - you just want to indicate that the key has changed.
As you say, you could use a POI that just displays info on the waveform, so when you load the track, the info is visible.
geposted Fri 16 Feb 24 @ 10:04 pm
That is what I would like to do.
Is there an action that will change the key information? I couldn't find anything in the key section of the list of verbs that will change the key information without actually changing the key.
geposted Fri 16 Feb 24 @ 10:07 pm
Changing the key information would change the key.
Your options are adding a marker to the waveform, or putting some info in the file tag so it's visible in the browser.
geposted Fri 16 Feb 24 @ 10:13 pm
Changing the key in the tag editor doesn't change the actual key of the song. That is the change I was hoping to make with a POI.
Is there no way to edit tags using VDJscript then?
geposted Fri 16 Feb 24 @ 10:32 pm
By "key information" I assumed you meant the key displayed on each deck, which although is sourced from the tag, does change the key of the track when modified with the key up/down controls.
Personally I think displaying the info on the waveform is a better option as it allows you to see that:
1) There is a key change in the track
2) Where the change happens
I'm not sure it's possible to change tags via script/POI actions.
Calling @locodog
Calling @locodog
geposted Fri 16 Feb 24 @ 11:38 pm
"I would like to use a POI action at key changes to let VDJ know that the song is now in Gm, but using set_key will instead shift it another minor third to Bb, which just makes Bon Jovi sound like the Chipmunks."
"Is there an action that will change the key information? I couldn't find anything in the key section of the list of verbs that will change the key information without actually changing the key."
Maybe you can get ahead with this:
-----> loaded_song "key" "gm"
However, you then have to get VDJ to use the original “Key Tag” from the song again.
Otherwise the changed "key tag" would be wrong forever...
So 1 more poi with the original value is needed.
geposted Sat 17 Feb 24 @ 12:45 am
That works perfectly. Thanks.
geposted Sun 18 Feb 24 @ 1:48 am
Calling @locodog
Calling @locodog
I'm also displaying it on the waveform by labeling the POI Gm.
Changing the tag data means that Auto Match Key will still do what it is supposed to, and the little key checkmarks in my list won't be lying to me anymore.
Using
loaded_song "key" "gm"did just what I wanted.
Thanks for your help.
geposted Sun 18 Feb 24 @ 2:03 am
