Hey guys,
So I moved all my Itunes music over to a hard drive. Before I did this, I could get Itunes to come up on my VDJ while it was on my computer hard drive. Now that I've moved it over, Itunes on my computer recognizes the hard drive, but VDJ does not.
What do I need to do to get VDJ to recognize the hard drive and be able to use my purchased itunes music on VDJ?
geposted Sun 18 Feb 24 @ 2:53 pm
If it's purchased music (not rented) then just point VDJ at the directory and let it scan all the files. You don't need to go via the iTunes database in the VDJ browser.
geposted Sun 18 Feb 24 @ 2:55 pm
Thanks. So I go to preferences, type Itunes in the search bar, put in the pat to the external hard drive, but then there is nothing under Itunes. I have hundreds of purchased songs, but it's brining up nothing.
geposted Sun 18 Feb 24 @ 3:16 pm
As I said, you don't need to do the whole iTunes database thing. If the music on the drive is purchased, just browse to the folder in VDJ and let it scan the contents.
geposted Sun 18 Feb 24 @ 3:25 pm
Ok. Thanks again. Gonna start following your stuff. You've been at this a long time.
geposted Sun 18 Feb 24 @ 3:44 pm
