I'm having an issue of lately where the audio knobs on the software screen are jumping eratically on its own with out me touching the controller. I noticed it only happens when I connect the controller. If I use the laptop only it doesn't happen
What could be causing this to happen help please
geposted Tue 05 Mar 24 @ 7:47 pm
I'm using a ddj 800 with virtual dj 2020 software of course it was working a few months ago with no issues. I had moved and wasn't able to play with my equipment for some time now, once I hooked it back up I also noticed the ddj jog wheel was telling me no driver. I just replaced the usb that connects it to the laptop and that issue is now working correctly
geposted Tue 05 Mar 24 @ 7:51 pm
Check controllerTakeoverMode setting.
It should be on "pickup". You may have it set on "instant" instead
geposted Wed 06 Mar 24 @ 8:07 am
It's set to pickup. but still having issues the controller connects, but the audio controls are not working in software when I use the controller on screen the gain trim high mid and low are fluctuating on its own
geposted Tue 02 Apr 24 @ 4:26 am
I bought 2 new usb and tried but still having this issue help please I have a gig coming up next week to bring in the warm weather with some tunes
geposted Tue 02 Apr 24 @ 4:27 am
If the controls are fluctuating on screen while you don't touch them, then you need to have your unit serviced.
This is indicative of hardware malfunction.
geposted Tue 02 Apr 24 @ 6:45 am
