The track I loaded on Deck 1 is not playing anthing after I click the play button, what should I do to fix this?
geposted Sat 09 Mar 24 @ 5:46 pm
Does the software show it playing and you just can't hear it? Is it audible on headphones? Are you using a controller? Mac or Windows? What VDJ build? Can you post a picture of your audio config?
geposted Sun 10 Mar 24 @ 12:30 am
