Hello there!
I am using a new dell i7 13 generation with great specs. I am running a vj 8 edition and I am using a pioneer ddj sb3.
Everything runs normally in the dj set until suddenly music stops. Frequency is like one time out of four or less.
Music stops, the controller loses its mapping and I disconnect it and reconnect it. The programme is not cashed, it will start the song right where it stopped (like it lost connection)
No incidents in windows, no errors.
I changed thecable with somethung shirt and expensive, nothing.
I changed all the settings in windows abiut updates or usb, nothing.
It happened in different places and different usb ports so it's not that.
Any ideas???
Any ideas???
geposted Thu 14 Mar 24 @ 11:37 am
If you don't have a license then VDJ will only allow you to use a controller for ten minutes.
geposted Thu 14 Mar 24 @ 11:46 am
Of course I have, If you dont it doesnt even recognize it! Any other idea?
geposted Thu 14 Mar 24 @ 2:49 pm
not true,
no licence gives you a 10 minute trial from boot and then stops working, exactly as you described.
geposted Thu 14 Mar 24 @ 3:40 pm
