Last couple of gigs I've had a crash while connecting to remote when it's waiting. When I press the connect button VDJ crashes and restarts.
I'm generally not online with that machine so not sure if a crashlog will have been uploaded.
Will do more testing after the weekend gigs.
geposted Fri 15 Mar 24 @ 10:18 pm
Tested again tonight using the same network connections and couldn't get it to crash. Only difference is that I didn't have my controller connected but can't see how that would make a difference anyway.
@adion can you please check and see if there are any crashlogs on my account?
Thank you!
Thank you!
geposted Mon 18 Mar 24 @ 7:09 pm
No crashes logged no. Some possible crashes have been fixed in vdj 2024 btw
geposted Tue 19 Mar 24 @ 5:04 am
OK, thanks. Just didn't want to put the 2024 version on my gig machine while it's still EA.
geposted Tue 19 Mar 24 @ 10:11 am
