Benz Werner wrote :
In Version 8044 > sideviewShortcuts "geniusdj:linked" no longer works
You probably created the geniusdj sideview shortcut with the previous Early access build.
Try to remove the shortcut and create it again with this version.
geposted Wed 27 Mar 24 @ 11:28 am
I've already done exactly that, but it still doesn't work
geposted Wed 27 Mar 24 @ 12:03 pm
I have now uninstalled and reinstalled VDJ but "geniusdj:linked" definitely no longer works
geposted Wed 27 Mar 24 @ 12:38 pm
locodog wrote :
@tsi setting browserAutoExportM3U
Doesn't work on my Mac, I can make a video showing the process if needed.
geposted Wed 27 Mar 24 @ 1:09 pm
the SOUND INSURGENT wrote :
With the newest update the "List" no longer show up in SoundSwitch. Also broke the connection with LEXICON 🤦🏾♂️
Anything I can do to fix this??
Just wait a bit. Christian is aware of that already. I bet it doesn't take him long to fix Lexicon. But he might have to wait until it's out of Early Access thought.
geposted Thu 28 Mar 24 @ 12:15 am
New notice: I just notice that history playlists can still be rearranged on the same level, but moving them to a subfolder (e.g. 2024) is no longer possible. They can't be erased either!
geposted Thu 28 Mar 24 @ 9:01 am
In the new version 8055 "sideviewShortcuts" only works sometimes.
Sometimes yes, then sometimes not
geposted Fri 29 Mar 24 @ 2:31 pm
So, what do you have in sideviewShortcuts ? And which of them work some times ?
geposted Fri 29 Mar 24 @ 2:59 pm
1. No display of linked tracks
2. Tracks are linked
3. Setting in SideviewShortcuts
geposted Fri 29 Mar 24 @ 4:11 pm
I have now restarted VDJ and the linked tracks can be seen
I restarted VDJ again and the linked trucks are not visible
geposted Fri 29 Mar 24 @ 4:24 pm
before a misunderstanding arises
I always use the browser as a source
not the active deck
not the active deck
geposted Fri 29 Mar 24 @ 4:28 pm
we will check why the shortcut isn't working, but in the meantime I just wanted to point that the expected way to see the linked tracks is by using the remix panel in linked track mode, this will be more reactive and gives you access to the linked track options directly:
geposted Fri 29 Mar 24 @ 4:54 pm
Hi Stephane, thank you very much for the prompt and friendly answer
I would like to note that I work with my own skin in which I have a separate window
with I can constantly monitor the ideas and the linked tracks without always having to switch.
Constantly clicking into another window is too much effort for me, that's why it should definitely
work with the "Shortcut linked Tracks".
Greetings from Germany
Werner
Werner
geposted Fri 29 Mar 24 @ 5:27 pm
Benz Werner wrote :
The linked track tab I pointed above is in the sideview, not in the browser.I have a separate window
It means you don't have to make a shortcut, it's already there by default (just by default it's called "remix", you can change it to be "linked track" instead in the menu)
geposted Fri 29 Mar 24 @ 5:44 pm
Yes, I know that Linked Tracks are in the sideview and I can switch there, but I want to see Linked Tracks and Ideas at the same time so that I can monitor them continuously without switching
geposted Fri 29 Mar 24 @ 6:09 pm
Benz Werner wrote :
You said that you have a skin which does that, but the pictures you posted show (what looks like) a default skin.I want to see Linked Tracks and Ideas at the same time
geposted Fri 29 Mar 24 @ 7:15 pm
groovindj wrote :
The pictures are from my test machine, so the standard skin can be seen here.
I have this skin on my gig machine that does this,
but only with VDJ version 7921, so it works perfectly (it doesn't work with version 8055).
geposted Fri 29 Mar 24 @ 7:25 pm
Could it be added, that one could select MORE then one of the above options to be displayed in that sideview tab?
(multiple select, instead of single select)
So that say, Alternative Remixes AND Linked Tracks could be displayed in the same tab?
(and the cherry... to allow the ordering of each, to be user configured, Alternative Remixes displayed .. under Linked Tracks)
An alternative: allow Linked Tracks to be displayed as a horizontal panel.
(as is done with showHorizontalSideList)
Either, above could accomplish, displaying BOTH, Linked Tracks, and other info without the need to toggle with every change of the browsed/played track.
(or any other alternative method to see Linked Tracks and say, Alternative Remixes at the same time would be awesome)
geposted Fri 29 Mar 24 @ 9:13 pm
since b8055: deleting history files is now possible! But moving it to a subfolder (e.g. 2024) is not yet possible ;-)
geposted Sat 30 Mar 24 @ 9:48 am
Besides all this videos no longer display well on window PCs
geposted Sat 30 Mar 24 @ 10:47 am
