Fuzzy key mixing. How can I use this function for color filters or Quik filters? For example, instead of Keydiff.
geposted Tue 19 Mar 24 @ 6:34 pm
keyDiff already takes it into account
geposted Tue 19 Mar 24 @ 8:02 pm
Okay thanks. And what is a sensible value for Keydiff? <2 or <4 what can you recommend? I'm currently using the filter like this. is that ohy?
geposted Tue 19 Mar 24 @ 8:32 pm
keydiff of zero will pick up all fuzzy matches
keydiff of 1 will pick up 16 of the possible 24 keys so not sensible
keydiff of 2 or more with fuzzy on is completely useless as it picks up everything
if you have fuzzy mixing on then only a keyDiff of zero is sensible.
geposted Tue 19 Mar 24 @ 9:00 pm
Thank you very much for the explanation, learned something again!!
geposted Tue 19 Mar 24 @ 10:02 pm
