Hi guys, is there any way to adjust the loop lenght by using the jog? In RekordBox is working fine but in VDJ I cannot figure out how to do it, is there any settings for that? Thanks!
geposted Tue 02 Apr 24 @ 1:04 pm
Are you using a controller ?
Which one ?
On most Pioneer controllers, adjusting the loop length should be similar to CDJ's.
Once in a loop, press the loop in or the loop out button and use the jog to adjust the loop in/out point respectively.
On other controllers it may vary.
On VirtualDJ GUI itself, you need to use the PRO interface, and then press the "LOOP" text next to the loop panel to see the extra features/adjustments.
Which one ?
geposted Tue 02 Apr 24 @ 2:03 pm
Yes, you can do that. Scroll down to the LOOPS ADJUST chapter https://virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/loops.html
Some controllers also have this feature in the factory Mapping. Any particular you are using ?
geposted Tue 02 Apr 24 @ 2:05 pm
I have a Pioneer Rev5
geposted Tue 02 Apr 24 @ 4:23 pm
geposted Tue 02 Apr 24 @ 10:11 pm
Solved ! Thank you guys !!!
geposted Wed 03 Apr 24 @ 3:28 am
