Hi,
I'll try to be as specific as I can:
I've been using the following script to split vocals to the other deck (1 to 3 and 2 to 4):
leftdeck ? stems_split 'vocal' ? on & deck 1 stems_split 'vocal' : off & deck 1 stems_split 'vocal' : stems_split 'vocal' ? on & deck 2 stems_split 'vocal' : off & deck 2 stems_split 'vocal' :
this works flawlessly.
Then I'm using this script that links (or unliks) the two tracks so you can scroll one wihtout affecting the other:
leftdeck ? stems_split ? deck 1 stems_split_unlink ? off & deck 1 stems_split_unlink : on & deck 1 stems_split_unlink : stems_split ? deck 2 stems_split_unlink ? off & deck 2 stems_split_unlink : on & deck 2 stems_split_unlink
This works flawlessly too.
So my problem:
Let's say Track A is playing on deck 1.
Ill use the first script to split the vocals to deck 3.
Then i introduce Track B on deck 2.
i use the "unlink" script so my deck 1 and 3 can move around freely.
Now i have transitioned from Track A to Track B.
At the moment Track B is playing with the voice stem of Track A on deck 3.
Problem here is when i try to load a new song to deck 1 it resets my stem pads and brings the full music back on deck 3.
I just want the voice from Track A to keep playing over Track B and being able to unload Track A from deck 1 without having all the stems coming back up!
Thanks in advance for your help!
So my problem:
geposted Wed 03 Apr 24 @ 6:58 pm
Hi Sneak A Poo,
I have the same issue/request for stems to not reset when one of the stem split decks is unloaded, along with another user Zeusmatic: https://virtualdj.com/forums/256925/Wishes_and_new_features/Stems_Way_Of_Functionality.html
geposted Wed 03 Apr 24 @ 7:27 pm
