Hi,
Is there anyway that we can use a button in a CDJ to switch decks, like we have for dual deck controllers, i don't think the script we have for dual deck controllers will work, coz the CDJs are recognised as separate equipment. help appreciated. So basically button i can use on the left CDJ to move from deck 1 to 3 and on the right CDJ to move from deck 2 to 4
Chad
Chad
geposted Thu 04 Apr 24 @ 2:40 pm
Holding down the EJECT button on the CDJ for more than 2 seconds, should do what u want i think
Or is it 2000NXS2 ?
Or is it 2000NXS2 ?
geposted Thu 04 Apr 24 @ 2:46 pm
no meant to run one CDJ for deck 1 and 3 and then the other to switch from 2 to 4
geposted Sun 26 Oct 25 @ 2:29 am
Or is it 2000NXS2 ?
Or is it 2000NXS2 ?
Yes it does, however since the mixer is 2 channel it just changes the focus not the playing deck. however on the S7 and the S9 mixes the deck change can be done by using the Channel selection knobs, by mistake i found this out this saturday. so dont need a button now.. lol
geposted Mon 27 Oct 25 @ 2:12 pm
