Question has Virtual DJ mapped or is planning to map Piano Play and Auto BPM Transition features for Rev 5. When I use Piano Play I get chipmunk vocals... and Auto BPM does seem to work.
geposted Thu 04 Apr 24 @ 10:50 pm
The first one is probably because you haven't enabled master tempo in VDJ
Try clicking the small "MT" on both decks so that it lights up
geposted Fri 05 Apr 24 @ 4:31 am
Auto BPM transition has been implemented in VDJ because of the rev5, so I'm nit sure why you can't trigger it. Here is how it generally works
geposted Fri 05 Apr 24 @ 4:36 am
