Hello. With the new update the order in browser for files with the bpm standard is gone. The new staff is to make new orders for the lists but it is very difficult to keep the order only with the bpm for all files! Can you please tell me how can I ll use the previous setting just to keep the order always with bpm without fixing anytime I change file??
Thank you in advance.
geposted Fri 05 Apr 24 @ 7:34 am
Hmmm....
For me it only changes if I click another column header - other than that the ordering for BPM (or any other column) stays between switching of lists, folders and even between VDJ sessions
UNLESS I enable the new "Keep order" feature on lists
That enables each list to have it's own columns and saved ordering
But that doesn't happen by accident. That's something you actively have to choose for a list
geposted Fri 05 Apr 24 @ 7:42 am
Thank you Klaus. The point is that I've tried the new keep order effect but doesn't work. Without changing columns, the bpm column needs to set every time I change file list. I've checked the options and have nothing about it. Do you have something in mind??
Thanks.
Thanks.
geposted Fri 05 Apr 24 @ 9:32 am
Keep Order on the list should be off if you want to see the list sorted by another field.
keepSortOrder in options should be set to Yes to remember that BPM was selected
geposted Fri 05 Apr 24 @ 9:53 am
Thank you adion. I will check again!!!
geposted Fri 05 Apr 24 @ 9:55 am
No my friend it doesn't work and the version is b8079
geposted Fri 05 Apr 24 @ 3:38 pm
Any column I select in a list,when I change list not keeping the order!!!
geposted Fri 05 Apr 24 @ 3:43 pm
I found it! You must turn off list by list the keep order choice!! It's very annoying!!!! Why we must do this??!?
Thanx anyway!!!!
Greetings from Greece!!!
Thanx anyway!!!!
geposted Fri 05 Apr 24 @ 3:54 pm
bonjour , j'ai un souci avec vdj et mon controleur gemini dmp7000.
les appareils connectés et reliés , quand j'ouvre vdj , je n'ai qu'un deck ,
le côté L qui se connecte.
on dirait que vdj ne tient pas en mémoire les 2 decks.
et après plusieurs, allume, éteint de vdj , le deck 2 se connecte.
dois enregistrer les paramètres à un endroit précis ?
merci de votre aide
merci de votre aide
geposted Fri 05 Apr 24 @ 4:06 pm
uncheck keep order on all lists
geposted Mon 06 May 24 @ 8:11 am
Well, it's a setting on the list, so it makes sense :)
geposted Mon 06 May 24 @ 8:20 am
Good day.
I would like to inquire about the process of transferring my data, including cues and playlists, from Traktor to VirtualDJ. Is there a need for any additional software to facilitate this transfer, or does VirtualDJ have the capability to perform it automatically?
Thank you for your attention to this matter.
geposted Fri 16 Aug 24 @ 1:23 pm
According to the User Manual, VirtualDJ should be able to read your Traktor Library.
I'm not sure of the track cue pointsvthat's stored to file, but given I know it reads Serato cue points it's highly likely it reads Traktor cuepoints too (others can correct me here).
Also, I think you can just download it and see how it works as well (download for non-professional use is free and has the full feature set).
geposted Fri 16 Aug 24 @ 2:21 pm
Thanks a lot in advance.
geposted Sat 17 Aug 24 @ 8:53 am
Not a problem. I also notice that the account you are using in this forum indicates you are a pro user so you can probably disregard all the free version info 🍺
geposted Sat 17 Aug 24 @ 2:31 pm
