Hi team,
I moved VDJ to a new PC. I did it according to your suggestions in VDJPEDIA.
Everything worked. I use comments field for my tracks where I store necessary info to the according tracks. The content of comments field from my beatport streaming tracks were all taken over to the new PC. The contents of comments field from my local files are lost.
How do I get the contents of my comments field from my local files transferred to my new PC? Old PC still exists.
Can you suggest something?
Thanks Tom
VDJ 2023 build 7831, Win 11
Thanks Tom
geposted Fri 05 Apr 24 @ 9:04 pm
Can you give us more information about your setup.
Are the tracks in the exact same folder as before, or a new folder but on the same drive, or the drive letter changed?
Did you move your old database.xml into the %appdata%/VirtualDJ/ folder? (you can access this folder by clicking on the small cog icon in the lower right corner of the options window)
geposted Sat 06 Apr 24 @ 7:14 am
Hey Stephane,
just fixed it some minutes ago. Database.xml was not copied correctly.
Now it works. Move to new PC completed!
Thanks
Tom
Thanks
Tom
geposted Sat 06 Apr 24 @ 7:38 am
