Last night my mix didn't record. It displayed file not opened for writing?
I've tried reinstalling the software but it won't record.
I have recorded over 200 mixes with no problem and have not altered any settings
Any ideas?
Any ideas?
geposted Sat 06 Apr 24 @ 5:59 pm
set the path to one where you can write to like my documents in windows
geposted Sat 06 Apr 24 @ 6:52 pm
use the 3 dots on the record window
geposted Sat 06 Apr 24 @ 8:24 pm
click the box with the three dots and when the window opens select a valid folder for the recording to go to, then give it a file name. you don't have to type in .mp3 or .mp4 - the software will automatically give it a file type depending what you chose from the dropdown menu for format,
geposted Sun 07 Apr 24 @ 12:08 am
