Hello there next week I will have a gig in a new club and I will share the consolle with another DJ who uses Serato DJ Pro.
The consolle configuration is as follows: 2 CDJ 2000 Nexus and 1 DJM S7 Mixer.
Now I read this instruction guide https://virtualdj.com/manuals/hardware/pioneer/clubsetup/digital.html and I understood it's pretty easy to use this setup with VDJ.
Furthermore I watched this video regarding the same configuration under Serato DJ Pro.
https://youtu.be/I5OsYDRzP_k
Now my question is:
If I connect the CDJ via USB cable to my USB Hub, how can the other DJ do the same with Serato if the CDJ USB port is already used and connected to my Laptop?
Any suggestions are welcome.
Thanks!
Now my question is:
Thanks!
geposted Sun 07 Apr 24 @ 5:45 am
I found this
https://www.youtube.com/watch?v=HQ1X79-3KvM
Does anybody knows if it works for VDJ too?
Please!
Please!
geposted Sun 07 Apr 24 @ 9:29 am
Yes, it should work like that. If the CDJs are plugged to the hub of the DJM-S7, then all you need to do is to connect your laptop to the free USB port A/B of the DJM and when ready to switch, use the SOURCE selectors on the DJM-S7 to select the relative USB A/B.
geposted Sun 07 Apr 24 @ 9:42 am
Thanks man....I need to try it first...I was looking for some real life experiences...
geposted Sun 07 Apr 24 @ 10:06 am
VDJ technical support just officially confirmed it's supported like reported in this video
https://youtu.be/HQ1X79-3KvM?si=er2LpvOZK8GR5xwV
geposted Mon 08 Apr 24 @ 5:27 pm
