I'm playing songs thru a portable hard drive... been playing fine, no problems. Yet in the last 48 hours the music plays for 20 seconds, then stops for 3 seconds then plays then stops and then just deterirates to useless garbage... Both decks. Can anyone help?
geposted Fri 12 Apr 24 @ 10:07 am
When this happens check in task manager to see if your computer is running out of RAM.
Could also be a buffer underrun. What controller and drivers are you using?
geposted Fri 12 Apr 24 @ 10:22 am
Also, it would not be a bad idea to check the drive via a S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) and/or Windows built in tool(s) for any faults.
geposted Fri 12 Apr 24 @ 12:13 pm
