I'm completely new user of Virtualdj. Why I don't see permanently the value of FX knobs? When I'm changing it, the value shows for a while than change to "STR", "POS" or "LEN". How to change it? I'm using performance skin
geposted Wed 17 Apr 24 @ 6:57 am
It is possible/can be done. Depends on the code used in the skin.
geposted Wed 17 Apr 24 @ 7:21 am
How? I'm using dedicated performance skin
geposted Wed 17 Apr 24 @ 7:27 am
The XML code used in the skin needs to be modified.
Here's part of a skin I made a few years ago.
geposted Wed 17 Apr 24 @ 7:48 am
Could you post here some peace of code to have permanently showed the fx value
geposted Wed 17 Apr 24 @ 8:27 am
The values are displayed in a textzone with the action get_effect_slider_text
geposted Wed 17 Apr 24 @ 8:42 am
If too hard for you to edit a skin (default or some other), you could still try to download other custom skins which could have this info displayed by default. Try the Blocks skin
geposted Wed 17 Apr 24 @ 12:50 pm
