have the history files moved? my history has dissapeared from one of my computers because I had to reinstall windows
but when i try to import the database from my other computer (checking the history only) it says "no history files have been imported"
when i look for them manually on either one of my computers, i cant find them anywhere in the VDJ folders
geposted Wed 17 Apr 24 @ 12:05 pm
Settings > options then click the cog in the bottom right corner.
That will open the home folder location and your history will be in there.
geposted Wed 17 Apr 24 @ 12:16 pm
There was a bug in some previous Build that wasnt adding History in the Database backup and there is a chance you used that Build to create your Database backup.
We invite you to use the latest Early Access Build 8115 in both of your computers by enabling the EarlyAccessUpdates setting and restart in order VirtualDJ to auto-update.
Once updated, use your "original" computer to create a new Database backup and try to restore using this file from your second computer.
geposted Wed 17 Apr 24 @ 12:20 pm
Yea that was it, Updated VDJ my second latpop that i was making the backup from, and now it worked.
thankyou !
thankyou !
geposted Wed 17 Apr 24 @ 12:22 pm
