When I create my side list, the folder isn't being saved as I created it, the songs are all over the place . It's not in the order that I put it.
geposted Thu 18 Apr 24 @ 1:11 pm
This is definitely a huge problem for me, before the update it was fine but ever since the update when even I had one of my sidelist folders that I already made to add a song to it the whole folder shuffle and won't save it the order I made it.
geposted Thu 18 Apr 24 @ 2:24 pm
Try the EA 8115 build to see if that fixes the issue.
Also this thread my be of interest:
https://virtualdj.com/forums/258099/VirtualDJ_Technical_Support/Problems_with_sidelist.html
geposted Thu 18 Apr 24 @ 2:41 pm
I got a update a few days ago and the problem as now been fixed thank u.
geposted Sun 05 May 24 @ 8:20 pm
