Hello! I have a DDJ-800 and I noticed that while playing on 3 or 4 decks at the same time and switching from deck 1 to 3, or 2 to 4, while the knobs remain on all decks as I have adjusted them in each deck, the volume faders lose their "memory" from each deck the minute I switch the decks. For example, on deck 2 I have adjusted the volume fader on 10 (maximum) and on deck 4 I set it in the middle of the fader range, when I switch back to deck 2, the volume fader readjusts itself in the middle of the fader range just like deck 4, but the knobs settings for each deck remain the way I put them, as they should have of course! This didn't happen up until now. Any solution? Thank you in advance!
geposted Fri 19 Apr 24 @ 9:31 am
