The History don't show the played Time anymore. Also in the Context Menu from the Browsercolum isn't a value.
geposted Sun 28 Apr 24 @ 7:29 am
Still showing here. Unless you manually changed browserColumns in settings it should also always be shown for history (which is why it's not in the column drop-down)
geposted Sun 28 Apr 24 @ 7:43 am
Yes i set all list (file, file=virt, file(hist),...) by copy & past for the same size.
I add the lost coluom "plti" now it works. ;)
geposted Sun 28 Apr 24 @ 8:02 am
