I use the Lottery feature for several monthly recurring events.
I would like to start and stop it with the remote so I can be away from the booth.
Is it possible now or can it be added with an update?
geposted Fri 03 May 24 @ 4:29 pm
possible now, just make a custom_button, and call it from the remote.
Depending on which slot you call lottery fx on, it's one of these.
deck master effect_button lottery 1
effect_button audioOnlyVisualisation 1
geposted Sat 04 May 24 @ 8:11 am
I can get it in my FX 3 slot, and adjust the slider for how fast/slow the lottery moves, but it is missing the Start/Stop button so it only loads the first image.
Is there any way to also add the Start/Stop button on the FX slot?
Thanks in advance!
Thanks in advance!
geposted Sat 08 Jun 24 @ 1:41 pm
A skin tweak would be needed to show it, but if you have a spare fx slot you could make a virtualfx to press the button as an fx
geposted Sat 08 Jun 24 @ 1:51 pm
