What's the script so whenever I move the crossfader to the opposite deck the bass knob turns down while I'm moving the crossfader?
geposted Thu 09 May 24 @ 2:14 pm
read up on the effect_mixfx scripts.
geposted Thu 09 May 24 @ 3:12 pm
It's called Smartfader. I found it.
geposted Thu 09 May 24 @ 5:38 pm
How do I make a script so whenever I move the crossfader it turns down the bass on the deck and moves the other one up similar to the smart fader?
geposted Fri 10 May 24 @ 11:25 pm
your slider has an implicit value it passes [0.0 - 1.0] , you manipulate that implicit with multiplication & addition till it's the value you need.
geposted Fri 10 May 24 @ 11:42 pm
Do what??
geposted Sat 11 May 24 @ 12:15 am
Do what?? I just wanna go and do what I just asked. I think it's a cool feature.
