Hello everyone!
I am facing an issue with some of my tracks regarding loading them on the first beat.
I have set the autocue option to first beat and i have also configured the first beat where i want it to be.
I have also created 2 custom buttons to test this, which set and goto the first beat (and it works).
I have also tried to do it manually through the POI Editor and the BPM Editor.
The problem is that some tracks despite all this, do not load on the first beat but on the automix generated points.
I have tried to reanalyse the songs and also deleted them and re-rendered them from Ableton Live.
I have tried to delete the auto-generated automix points but then the songs load from the very start (not first beat).
Setting:
https://ibb.co/zXFHtmW
# Example Song
Where the song loads, despite having the First Beat set up:
https://ibb.co/ysRBK0w
BPM Editor:
https://ibb.co/Sw115Yc
POI Editor of where it loads:
https://ibb.co/dp5TfrG
POI Editor of First Beat:
https://ibb.co/Tm9X18G
Does anyone have an idea of what it could be happening?
Setting:
# Example Song
BPM Editor:
geposted Fri 10 May 24 @ 11:16 am
For autocue, VDJ indeed uses the automix 'Cut In' point, so if you want to change this, you should move the 'cut in' point as well
geposted Fri 10 May 24 @ 7:56 pm
